In Pokémon Legends: Z-A, many players are eager to add Simipour to their team. As a Water-type Pokémon, it can be a powerful ally in various battles. But how exactly do you catch or buy Simipour in the game? Here’s everything you need to know to get your hands on this unique Pokémon.
Catching Simipour in Pokémon Legends: Z-A
Simipour isn’t a Pokémon you can find just anywhere in Pokémon Legends: Z-A. It requires a bit of effort to locate, so let’s dive into the steps.
Simipour is typically found in water-based environments, often near rivers or lakes in the game world. You’ll need to explore these areas thoroughly to find this elusive Pokémon. Keep in mind that Simipour may not appear in the same location every time, so patience is key.
Time of Day:
Like many Pokémon, Simipour has specific times when it’s more likely to appear. While some Pokémon are available 24/7, Simipour might only show up during certain times of the day or in specific weather conditions. Check the game’s time system and look out for weather patterns that favor Water-type Pokémon.
Poké Ball Types:
When trying to catch Simipour, don’t forget to bring a variety of Poké Balls. A standard Poké Ball might do the job, but if Simipour is proving tricky, try using Great Balls or Ultra Balls for a higher catch rate.
Buying Simipour in Pokémon Legends: Z-A
If you’re not in the mood to hunt for Simipour in the wild, there’s another option: buying it.
In-Game Shop:
In Pokémon Legends: Z-A, you can purchase certain Pokémon from in-game vendors or special shops. These shops occasionally offer rare or hard-to-find Pokémon for a fee. While Simipour may not always be available, it’s worth checking the shop periodically to see if it’s on sale.
Trade Networks:
Another way to acquire Simipour is by using the game's trade system. You can trade with other players or NPCs who may have caught multiple Simipour. Be sure to check for active trade networks, as players often offer Pokémon they no longer need in exchange for ones that they do.
Tips for Training Simipour
Once you have caught or bought Simipour, it’s time to level it up and make it a formidable member of your team.
Move Set:
Simipour has a strong set of Water-type moves like Hydro Pump and Surf, making it useful against Fire, Ground, and Rock-type Pokémon. Make sure to focus on its Special Attack stat to maximize damage output in battles.
Held Items:
Items like the Water Gem or Choice Specs can significantly boost Simipour’s effectiveness in battle. Depending on your strategy, these items can help Simipour deliver devastating moves faster or more frequently.
Where to Use Simipour
Simipour is an excellent addition to your team, especially if you’re heading into battles against Fire or Ground-type opponents. Its Water-type moves provide a solid advantage, and with the right training, it can become a key asset in your Pokémon team.
Simipour can also be a great choice for taking on tough Gym Leaders or completing specific missions that require high-level Water-type Pokémon. Whether you catch or buy Simipour, it’s a valuable asset that will serve you well throughout your journey in Pokémon Legends: Z-A.
How to Catch or Buy Simipour in Pokémon Legends: Z-A – A Complete Guide
CyberHawk_7
