If you’ve spent any time in Helldivers 2, you already know that medals are more than just bragging rights—they’re a key part of tracking your progress, unlocking rewards, and showing off your accomplishments to your squad. But if you’re like most players, you might be wondering about the Fastest Ways To Earn Medals In Helldivers 2. Whether you’re a newcomer or a seasoned veteran, there are strategies you can adopt to maximize your medal count without burning yourself out.
Focus on High-Reward Missions
Not all missions are created equal when it comes to medals. While easier missions can feel safer, they often offer lower medal payouts. I’ve found that targeting mid-to-high difficulty missions usually provides the best return for your effort. Look for objectives that are dense with enemies or have bonus tasks. These missions might take a bit longer, but the medal payoff is almost always worth it.
Tip: Pay attention to mission alerts or limited-time events—they often give bonus medals for completion. These can significantly boost your medal count in a short amount of time.
Play With a Coordinated Squad
Helldivers 2 really shines when you play as a team. Running missions solo can be fun, but you’ll often take longer to complete objectives and may miss out on bonus medals that come from teamwork. Coordinating with friends or even online teammates can make a huge difference.
When everyone in the squad focuses on specific roles—like one person handling crowd control while another secures objectives—you can complete missions faster and more efficiently. Faster mission completion usually translates directly into more medals earned.
Prioritize Objectives Over Kills
It’s tempting to go after every enemy you see, but chasing kills isn’t always the fastest way to earn medals. Instead, prioritize completing mission objectives first. Whether it’s capturing a point, defending an area, or securing resources, finishing the main objectives tends to provide higher medal rewards.
That said, don’t completely ignore combat. Some objectives require clearing areas of enemies, and eliminating threats efficiently will keep your squad alive and mission momentum high. Balancing objective focus with smart combat is key to maximizing medals.
Make the Most of Reinforcements and Equipment
One of my favorite ways to speed up missions is to take full advantage of reinforcements and equipment. Calling in support at the right time—like airstrikes, turrets, or ammo drops—can save you precious time and prevent mistakes that could cost your squad valuable medals.
Choosing equipment that complements your squad’s playstyle also helps. For example, a heavy weapon user can clear large groups of enemies quickly, while a medic can keep the team alive during tricky encounters. The smoother your run, the faster you can complete missions and earn medals.
Replay Missions Strategically
Not every mission has to be a one-time adventure. Once you know the layout, enemy types, and best strategies, replaying missions can be one of the Fastest Ways To Earn Medals In Helldivers 2. Efficiency improves dramatically after the first run because you’re already familiar with the terrain and objectives.
I personally like to mark missions that gave me high medal rewards and return to them when I want a quick medal boost. It feels a bit like farming, but it’s way more satisfying when you see your medal count climb steadily.
Keep an Eye on Time-Limited Challenges
Helldivers 2 often includes daily, weekly, or event-specific challenges. These usually offer bonus medals for completing specific tasks or objectives. Ignoring these challenges is a missed opportunity because they can be an incredibly fast way to rack up medals without committing to long missions.
A simple tip: log in daily and check the challenges before choosing a mission. Completing even one or two of these challenges during your regular play session can add up over time.
Personal Takeaway
From my experience, the key to maximizing medals in Helldivers 2 is a mix of smart mission selection, teamwork, and strategic replaying. It’s easy to get caught up in combat excitement, but keeping an eye on objectives and using your squad effectively will reward you with medals faster than simply grinding kills.
Remember, medals are about efficiency as much as skill. Sometimes taking a slightly more challenging mission with clear strategies can earn you more medals than grinding easier levels endlessly. Play smart, coordinate with your squad, and make use of every tool at your disposal—and you’ll see your medal count skyrocket.
Mastering the Battlefield: Fastest Ways To Earn Medals In Helldivers 2
MysticTiger
