Arc Raiders Extended Medium Mag III Blueprint Location Guide
CyberHawk_7
Messaggio da CyberHawk_7 »
In Arc Raiders, the Extended Medium Mag III is a powerful modification that can significantly enhance your weapon's ammo capacity. This guide will walk you through the steps of obtaining the blueprint for the Extended Medium Mag III, including where to find it, how to craft it, and the benefits it brings to your gameplay.
What Is the Extended Medium Mag III?
The Extended Medium Mag III is a modification that increases the magazine size of compatible weapons that use medium ammo. This mod is particularly useful in long, drawn-out engagements where you need to maximize your ammo efficiency. When equipped, it gives a +12 magazine size, which can make a significant difference during battles.
Compatible Weapons:
Arpeggio
Osprey
Renegade
Torrente
Tempest
Venator
This mod can be a game-changer for players who prefer weapons that use medium ammo. With this upgrade, you can focus more on fighting and less on reloading, making it a valuable addition to your arsenal.
How to Find the Extended Medium Mag III Blueprint
The Extended Medium Mag III blueprint is locked, which means you cannot just buy it from a vendor or loot it from enemies. Instead, you'll need to obtain it through the following methods:
Scavenging: This method involves searching for the blueprint in various locations on the map. While the drop rate can be low, it's one of the ways to find this mod.
Crafting: The most reliable way to obtain the blueprint is through crafting. To do this, you need to gather the necessary materials, which we'll cover in the next section. Crafting also requires you to have Gunsmith 3 level unlocked.
The Extended Medium Mag III blueprint can be found in various locations around the map, and scavenging can be a time-consuming process. However, once you unlock it, you will be able to craft the mod anytime you need it.
Materials Needed to Craft the Extended Medium Mag III
If you want to craft the Extended Medium Mag III mod, here are the materials you'll need:
2× Mod Components
5× Steel Spring
You’ll also need to have Gunsmith 3 unlocked. If you're unfamiliar with Gunsmith 3, this is a crafting skill that allows you to create more advanced mods and weapons. It’s an important skill to level up if you want to make the most of the mods available in the game.
Once you've gathered the materials and unlocked the crafting skill, you can craft the Extended Medium Mag III mod and equip it to any compatible weapon. It’s a straightforward process, and once you’ve crafted the mod, it’s yours to use indefinitely.
Recycling and Salvaging the Extended Medium Mag III
If you ever need to get rid of the mod, either because you no longer want it or because you need the materials for another project, you can recycle or salvage it.
Recycling: If you recycle the Extended Medium Mag III, you’ll get back 1 Mod Component and 2 Steel Springs.
Salvaging: If you decide to salvage it, you’ll receive 2 Mechanical Components.
These materials are useful for crafting or upgrading other mods, so don’t hesitate to salvage the mod if it’s no longer useful to you.
Why Use the Extended Medium Mag III?
There are many benefits to using the Extended Medium Mag III in Arc Raiders:
Increased Ammo Capacity: The +12 magazine size means fewer reloads, which is crucial in long battles.
Improved Efficiency: With more ammo in your magazine, you can stay in the fight longer, making you more effective in combat.
Versatility: The mod is compatible with several different weapons, including the Arpeggio, Osprey, Renegade, Torrente, Tempest, and Venator. This means you can use it with many of the best weapons in the game.
Can I Buy the Extended Medium Mag III Blueprint?
Currently, the blueprint for the Extended Medium Mag III is not available for purchase through regular vendors in Arc Raiders. You must either scavenge for it or craft it using the necessary materials. However, if you want to skip the hunting and crafting process, you can always buy Snap Hook blueprint from other players or marketplaces.
The Extended Medium Mag III is an essential mod for players looking to maximize their weapon's ammo capacity in Arc Raiders. Whether you’re scavenging for it or crafting it yourself, this mod can make a significant difference in your gameplay by reducing the need for constant reloading. Just make sure you have the right materials and the Gunsmith 3 skill to craft it. Once you have it, you’ll be able to equip it to your favorite weapons and enjoy the benefits of increased ammo capacity during your battles.
Photoelectric Cloak | All Platform
