In Path of Exile 2, the customization of character builds goes far beyond skill gems and gear. One of the most nuanced systems returning from the original game is the Anoint system, a mechanic that allows players to enchant their amulets (and other gear types in specific contexts) with powerful passive skills using Oils. Whether you're a theorycrafter or a min-maxer, understanding the PoE 2 Anoints List and making smart use of an Anoints Calculator Cheat Sheet is essential to getting the most out of your build.
What Are Anoints and How Do They Work in PoE 2?
Anoints allow you to unlock any notable passive skill from the passive skill tree without actually having to path to it. This is achieved by applying a combination of three Oils to your amulet. Each combination unlocks a specific notable, giving your character a significant boost—whether it’s additional damage, defense, or utility.
In Path of Exile 2, the system has been refined. While the core mechanics are similar to the first game, the expanded passive tree and rebalancing of Oils mean players will need to familiarize themselves with a fresh PoE 2 Anoints List to stay competitive and efficient.
Why Use a PoE 2 Anoints Calculator Cheat Sheet?
With dozens of Oils and hundreds of potential notable passives, guessing combinations or scrolling through community wikis mid-game is both tedious and inefficient. That’s where an Anoints Calculator Cheat Sheet comes in handy. These tools allow you to input the notable you want and instantly receive the Oil combo required.
Veteran players often keep a printed or digital version of the cheat sheet handy while mapping or crafting, saving time and maximizing effectiveness. Especially in trade leagues, knowing which Oil combinations are valuable can also help you make better decisions in the economy.
Best Practices for Using the PoE 2 Anoints List
1. Prioritize Your Build's Needs:
Before selecting an Anoint, consider your build’s primary damage source and survivability bottlenecks. For instance, a crit-based Ranger might benefit more from “Heartseeker” than a tanky Marauder, who might prefer “Soul of Steel”.
2. Check for Synergies:
Anoints should not be chosen in isolation. Consider how the chosen passive works with your Ascendancy, skill gems, and other passive allocations. Use the PoE 2 Anoints List to find lesser-known but highly synergistic notables.
3. Trade and Farm Intelligently:
Some Oils are rarer than others. Knowing which combinations are high-value can help you decide whether to use or sell them. Keep your Anoints Calculator Cheat Sheet nearby when looting Blight encounters or shopping for Oils.
Notable Anoints Worth Considering
Here are a few popular notables to look out for in PoE 2, based on current community builds:
Tranquility (Energy Shield builds)
Dirty Techniques (Damage Over Time)
Arcane Chemistry (Flask effectiveness)
Divine Fervour (Spell builds)
Growth and Decay (Chaos builds)
Remember, the meta evolves, and so does the value of certain Anoints. Always refer to an updated PoE 2 Anoints List before investing rare Oils.
The Anoint system in Path of Exile 2 is a powerful layer of passive customization that every player should master. Whether you’re trying to squeeze extra DPS out of your crit build or shore up your defenses for endgame content, leveraging the PoE 2 Anoints List alongside an Anoints Calculator Cheat Sheet is a simple but essential strategy.
Take time to plan your Anoints ahead of time. With the right passive in place, a good build becomes great—and in a game as punishing as Path of Exile 2, that edge can make all the difference.
Mastering Passive Power: A Complete Guide to PoE 2 Anoints and Anoint Calculator Usage
