CWWK AMD-8845HS ITX Home NAS/Server motherboard
Topic dedicato alla scheda madre CWWK con cpu AMD-8845HS in formato ITX adatta come home NAS/Server
Link ufficiale produttore: https://cwwk.net/products/cwwk-amd-7735 ... otherboard
Immagini ufficiali:
Codice: Seleziona tutto
| Motherboard features  | - Matte black PCB                                            |
|                       | - High‑density moisture‑free 10‑layer circuit board          |
|                       | - Full protection (USB, audio, network)                      |
| Processor             | - Ryzen 7 8845HS (8C/16T) 16MB Up to 5.1 GHz w/ Radeon 780M  |
| Network card          | - 4 × Intel i226‑V 2.5G RJ45                                 |
| Memory                | - 2× SO‑DIMM DDR5                                            |
|                       | - Default: 5600 MT/s (supports 4800/5200)                    |
|                       | - Max single: 32GB                                           |
|                       | - Max dual channel: 64GB                                     |
| Storage               | - 2 × M.2 NVMe PCIe 4.0 x2 (front+back, 2280)                |
|                       | - 2 × SFF‑8643 → fino a 5 SATA3 (6Gbps)                      |
| TDP                   | - 35–54W                                                     |
| Power supply          | - ATX 24‑pin + 8‑pin                                         |
|                       | - Consigliato ≥ 500W con 9 dischi                            |
| Onboard interfaces    | - 2 × SFF‑8643 (4× SATA3)                                    |
|                       | - 1 × SATA3 port                                             |
|                       | - 1 × SATA 4‑pin power                                       |
|                       | - 2 × USB2.0 sockets                                         |
|                       | - 1 × PCI‑E x16 (x8 signal)                                  |
|                       | - 1 × JCOM header                                            |
|                       | - 1 × FPANEL LED/PWR                                         |
|                       | - 1 × 4‑pin fan header (2.54)                                |
|                       | - 1 × TPM header                                             |
|                       | - 1 × USB2.0 pin                                             |
|                       | - 1 × USB3.2 pin                                             |
|                       | - 2 × M.2 NVMe PCIe 4.0 x2 (2280)                            |
|                       | - 1 × ATX 24+8‑pin power                                     |
| IO panel              | - 2 × USB3.2                                                 |
|                       | - 1 × DP 1.4                                                 |
|                       | - 1 × HDMI 2.0                                               |
|                       | - 1 × USB‑C (USB4)                                           |
|                       | - 4 × USB2.0                                                 |
|                       | - 4 × Intel 2.5G RJ45                                        |
|                       | - 1 × Audio                                                  |
| Structure             | - Mini‑ITX 17×17 cm                                          |
|                       | - Solid State Capacitor Design                               |
| Operating system      | - Windows 10/11 64‑bit                                       |
|                       | - Linux                                                      |
|                       | - EFI mode only                                              |
