If you’ve been playing Warborne Above Ashes for a while, you know how valuable Solarbite can be. Whether you’ve earned it through daily quests, events, or decided to buy Solarbite Warborne style, spending it wisely can make a huge difference in your progression. I’ve spent a lot of time experimenting with different strategies, so here’s my take on the best ways to maximize your Solarbite.
1. Upgrading Your Heroes
One of the most effective ways to use Solarbite is by upgrading your heroes. Stronger heroes can make a significant impact in both PvE and PvP battles. Prioritize upgrading heroes that fit well into your main team composition or those with versatile abilities. Even a small boost can turn the tide in critical encounters, and it’s often a more reliable investment than splurging on one-off items.
2. Enhancing Equipment
Investing in equipment enhancements can be another smart use of Solarbite. The stat boosts you gain from upgraded gear scale well with your heroes’ levels, meaning every Solarbite spent here has long-term benefits. Make sure to focus on gear that complements your main lineup’s strengths. This ensures your Solarbite has a tangible impact rather than being spread too thin.
3. Unlocking Special Events or Packs
Warborne Above Ashes occasionally offers limited-time events or packs that require Solarbite. While these can be tempting, I recommend checking whether the rewards are worth the investment. Events that grant powerful heroes, rare equipment, or large Solarbite returns are usually the best options. Players who are strategic about these events often come out ahead in terms of progression.
4. Saving for Rare Hero Summons
If you’re aiming to build a top-tier roster, saving your Solarbite for rare hero summons can be worthwhile. Pulling heroes during special banners can provide significant advantages, especially if the heroes synergize with your existing team. I usually advise accumulating Solarbite rather than spending it on smaller, incremental gains unless there’s an urgent upgrade needed.
5. Exploring U4GM for Guidance
Sometimes, it helps to see how other experienced players manage their Solarbite. Platforms like U4GM can provide insights on optimal spending strategies, helping you avoid common pitfalls and focus on what truly boosts your progress. While it’s not necessary to rely on external advice, seeing different approaches can inspire new strategies and help you spend your resources efficiently.
Overall, the key to spending Solarbite effectively in Warborne Above Ashes is to prioritize long-term growth over short-term gratification. Upgrading heroes and gear, participating in selective events, and saving for rare summons are all ways to get the most value from your Solarbite. By planning ahead, you can ensure that every Solarbite you spend contributes meaningfully to your journey through the game.
U4GM - Best Ways to Spend Solarbite in Warborne Above Ashes
