GeiL one W BH5 2*256Mb certificate cas 1.5 2 2 5 @200MHz e 2 2 2 5 @250MHz
usate pokissimo
Acquistate il 30/09/2005 ma montate il 19/10/2005(data d'arrivo della mia vga )
hanno garanzia a vita e le vendo @75€
ecco le specifiche.............
GeIL ONE Series BH Version Hand-picked (BH) 32x8 DDR Chips PC3200 400MHz DDR SDRAM. Capable running at DDR400MHz CAS 1.5-2-2-5 and DDR 500MHz CAS 2-2-2-5.
Available in 512MB Single Package, 512MB (2X256MB) and 1GB (2x512MB) Dual Channel Kit Package.
Specification
GeIL ONE hand-picked (BH) 32x8 DDR Chips
184-pin, Non-ECC, Un-buffered DDR DIMM
Working Voltage 2.55V - 3.80V
Platinum Copper Heatspreader
Retail Package
Lifetime Replacement Warranty
*DISCLAIMER - Attention all users of GeIL ONE W (BH) Series, in order for your GeIL ONE W (BH) to be covered in the full lifetime warranty policy, the modules must be working under the below requirements of condition.
VOLTAGE: All GeIL ONE W (BH) memory modules require a working voltage range between 3.4V ~ 3.5V @ DDR500
COOLING: All GeIL ONE W (BH) memory modules require sufficient cooling. A 15~25CFM (Cubic Feet per Minute) of direct airflow towards the modules is strongly recommended. This could be easily accomplished with an 80mm low rpm fan installed on the side panel of the chassis/case. Modules that are not properly cooled may not meet the rated timings/speeds stated in official spec and could become susceptible or premature.
PLATFORM: All GeIL ONE W (BH) were tested on DFI Athlon 64 platforms. Only Socket 939 platforms are validated to run at rated timings/speeds. GeIL strongly recommend for the GeIL ONE W (BH) to only be used on DFI LanParty UT NForce 4 Ultra-D, DFI LanParty UT NForce4 SLI-DR and DFI LanParty NForce4 SLI-DR as they are the few mother boards on the market right now that provide the best combination of voltage options and compatibility.
in vendita su altri forum
(ME PA) Geil one w BH-5 cas 1.5
Regole del forum
- Neoxxx
||A64 VeNiCe 3200@3800+ DaiLy||AC FreeZer 64||DFI LanParTy NF4 Ultra-D||2x256Mb GeIL ONE w 1.5-2-2-5||SaPpHirE FiReBlaDe X800GTO@X850PRO|| ||Zalman VF700cu||AuDigY||MaXtoR 160Gb SATA||PioNeeR DVD-120s||PioNeeR DVR-110||ThErMalTaKe ShArK||OCZ ModStrEaM 450W||LoGiTecH®Z5300||
