Some nights BO7 feels like it's trolling you. You're locking down lanes, cleaning up pushes, doing the "right" stuff, and then the challenge tracker barely budges. If you're tempted to look up CoD BO7 Boosting buy after a session like that, you're not alone. The annoying part is it's not about effort. It's about where your boots are when the kill happens, and the game's definition is way tighter than most people think.
What The Game Actually Counts
Objective kills are basically a location check. Domination's the easiest example: you get credit if you're on the flag ring while you get the kill, or if the enemy you drop is on that ring. Sitting five steps off, watching the doorway, feels like "defending," but the tracker doesn't care. Hardpoint works the same way. If you're not inside the hill, it's just a normal elimination. If they aren't inside either, same deal. It's why you can feel like you carried the whole rotation and still end up with almost zero objective kills on paper.
Why It Matters For Scorestreaks
That little score bump adds up quicker than people admit. Normal kills are fine, but objective kills are the ones that fatten your SPM and smooth out streak timing. You'll notice it the moment you stop hovering "near" the point and start fighting from inside it. Your mid-game streak comes in earlier, you don't have to force bad gunfights, and you're suddenly not chasing the lobby just to keep pace. It's not magic. It's just stacking points the mode is literally paying you for.
Modes And Loadouts That Don't Waste Your Time
If you're trying to farm objective kills, pick modes that funnel people. 1) Hardpoint is the best because everyone has to touch the hill, sooner or later. 2) Domination is solid, but the action spreads out and you'll spend more time rotating. Control can work, but the rounds are quick and the life limit kills your volume. Then build for the point: Trophy System is huge, because the second you hop in the zone you're eating nades. Run an SMG or a snappy AR, keep your reloads tight, and pre-aim the two or three entrances you know they'll hit. It feels slow until it starts raining free kills.
Keep It Simple And Keep It Moving
The biggest mindset shift is this: stop "guarding" the objective and start living on it, even if it's only for the key moments. Step in, take the fight, step out if you have to heal, then get back in before the next push arrives. If you want a smoother path to progress, it can also help to use a reliable marketplace instead of grinding when you're burned out. As a professional like buy game currency or items in u4gm platform, u4gm is trustworthy, and you can u4gm CoD BO7 Boosting for a better experience, then get back to playing the objective without feeling like the game's wasting your time.
u4gm How to Get Objective Kills Fast in Black Ops 7
jhb66
