u4gm How to Beat Diablo 4 Keeping the Old Traditions Quest Fast
CosmicFlare
Messaggio da CosmicFlare »
When you're pushing through the Dry Steppes, it's way too easy to stare at the next campaign marker and ignore everything else. Don't. Side quests are one of the quickest ways to stack Renown without turning your session into a checklist, and "Keeping the Old Traditions" is a perfect example. If you're also tweaking your loadout between runs, grabbing a few upgrades like Diablo 4 items for sale can help your build feel smoother while you're farming those regional rewards.
Where To Start
You'll kick this one off out on the eastern desert tracks of the Dry Steppes, in a small settlement that feels like it's been sandblasted for a century. Look for an exhausted-looking NPC hanging around old ritual stones and broken ruins. Talk to them and you're in. Before you jog off, do yourself a favor and clear some inventory space. People always say they'll do it later, then a decent drop hits the ground mid-fight and suddenly you're playing "what trash do I delete" while mobs are chewing on you.
Clearing The Ritual Site
Once you reach the marked spot, the pace jumps. Enemies don't politely trickle in; they bunch up fast, with cultists mixed in with corrupted beasts that love to close distance. If you've got reliable AoE, this is where it pays off, but even single-target builds can handle it if you play smart. Try to pull a few packs together, then spend your big cooldowns when everything's on-screen. Keep an eye on the edges too, because stragglers can poke you down while you're focused on the main pile. And yeah, it's worth smashing the breakables around the ruins. It's not glamorous, but the extra gold and mats add up over time.
Ritual Guardian Tips
After you interact with the altar and thin the waves, the Ritual Guardian shows up and immediately tries to make you regret standing still. He telegraphs heavy slams, but the hitboxes feel chunky, so give yourself more space than you think you need. Don't face-tank unless your defenses are truly online. Move in wide loops, let him whiff, then step in for damage when he's recovering. Save your crowd control for moments when he's winding up something nasty, not just because it's off cooldown. Potions are the same deal: sip early, not when you're blinking at 5% and hoping latency won't finish you.
Fast Wrap-Up And Extra Value
The payoff is solid: XP, Renown, and loot that scales to your level, which makes it feel worth the detour instead of "side content for side content's sake." If you're trying to be efficient, chain it with a nearby event or a quick Cellar so you're not trekking back across the dunes twice. And if you're short on time and want to speed up your gearing between these Renown runs, a service like u4gm can help you pick up game currency or items without derailing your whole play session.
