Salve, non riesco a masterizzare i dvd+RW e -RW, ad un certo punto della scrittura mi da write error.
Questo è il log:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programmi\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18.35.34
Nero version: 6.6.0.5
Recorder: <_NEC DVD_RW ND-2500A> Version: 1.06 - HA 0 TA 0 - 6.6.0.5
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <PIONEER DVD-ROM DVD-116 >Version: 1.22 - HA 0 TA 1 - 6.6.0.5
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DVD_RW ND-2500A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-ROM DVD-116 atapi Port 0 ID 1 DMA: On
DiskPeripheral : Promise 1+0 Stripe/RAID01.10 fasttx2k Port 2 ID 0 DMA: Off
DiskPeripheral : Promise 1+0 Stripe/RAID01.10 fasttx2k Port 2 ID 1 DMA: Off
CdRomPeripheral : AC1621B YEA037L 1.0 dtscsi Port 3 ID 0 DMA: Off
CdRomPeripheral : AC1621B YEA037L 1.0 dtscsi Port 3 ID 1 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-2500A D: CDRom0
PIONEER DVD-ROM DVD-116 E: CDRom1
AC1621B YEA037L I: CDRom2
AC1621B YEA037L J: CDRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048084kB)
Free physical memory: 321MB (328720kB)
Memory in use : 68 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.5.2006
UDF/ISO compilation
17.04.58 #1 Phase 112 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation started
17.04.58 #2 Phase 114 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation completed (no file modified)
17.04.58 #3 Text 0 File Isodoc.cpp, Line 6168
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
17.04.58 #4 Phase 111 File dlgbrnst.cpp, Line 1832
DVD-Video files sorted
17.04.58 #5 Text 0 File Reader.cpp, Line 127
Reader running
17.04.58 #6 Text 0 File Writer.cpp, Line 122
Writer _NEC DVD_RW ND-2500A running
17.04.58 #7 ISO9660GEN -11 File geniso.cpp, Line 3286
First writeable address = 0 (0x00000000)
17.04.58 #8 ISO9660GEN -11 File geniso.cpp, Line 3286
17.04.59 #9 Text 0 File Burncd.cpp, Line 3155
Turn on Disc-at-once, using DVD media
17.05.02 #10 Text 0 File DlgWaitCD.cpp, Line 257
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2187865 (486:11.40, 4273MB)
17.05.02 #11 Text 0 File DlgWaitCD.cpp, Line 269
Write in overburning mode: NO (enabled: CD)
17.05.02 #12 Text 0 File DlgWaitCD.cpp, Line 2310
Recorder: _NEC DVD_RW ND-2500A, Media type: DVD+RW
Disc Manufacturer ID: PHILIPS, Media Type ID: 041, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 1
17.05.02 #13 Text 0 File DlgWaitCD.cpp, Line 431
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: DVD+RW. Medium required by compilation: DVD+R/RW; DVD-R/RW.)
This disc is not empty.
Accessing disc...
17.05.02 #14 Text 0 File ThreadedTransferInterface.cpp, Line 829
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2188016 (2188016) = #2188016/486:13.41
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2188016 blocks [_NEC DVD_RW ND-2500A]
17.05.02 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1042
Prepare recorder [_NEC DVD_RW ND-2500A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4481056768, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2188016 | lead-out | 1 | 0x41 | 0x00
17.05.02 #16 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
17.05.02 #17 Text 0 File Burncd.cpp, Line 4042
Cache writing successful.
17.05.02 #18 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
17.05.02 #19 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5.540 KB/s)
17.05.03 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2604
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
17.05.03 #21 Text 0 File Cdrdrv.cpp, Line 8332
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 253A6F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 1 h
Disc Manufacturer ID: PHILIPS.
Media type ID: 041
Number of Physical format information bytes in use in ADIP up to byte 63: 57
Media Specific [16..63]:
00 00 01 50 48 49 4C 49 - 50 53 00 30 34 31 00 39 ...PHILIPS.041.9
23 00 9F 7C 5C 02 28 00 - 9A 7E 70 02 28 00 A0 7B #..|\.(..~p.(..{
68 02 28 04 04 20 E0 00 - F0 00 00 00 00 00 00 00 h.(.............
17.05.03 #22 Text 0 File DVDPlusRW.cpp, Line 606
Start write address at LBA 0
DVD high compatibility mode: Yes
17.17.56 #23 SCSI -1135 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03170000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x20 0x99 0x40 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
17.17.56 #24 CDR -1135 File Writer.cpp, Line 311
Write error
17.17.57 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
17.17.57 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
17.17.57 #27 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5.540 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 04/04/2006 21.29.28 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=?.?.?.?, size=95360 bytes, created 03/08/2004 22.59.44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\CPUCooL (Power saving: CPUCooL)
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
masterizzazione fallita con nec 2500A
- mosca123
