IL DISSIPATORE E' NUOVO....GARANZIA COMPLETA ZALMAN....COMPLETO DI TUTTO IL BUNDLE NEL SUO SCATOLO ORIGINALE!!!!
CNPS7000B-Cu LED
- Dimensions : 109 (L) x 109 (W) x 62 (H) mm
- Weight : 755g
- Base Material : Pure Copper
- Dissipation Area : 3,154 cm2
- Bearing Type : 2-Ball
- Speed : 1,350 ~ 2,600 rpm ± 10%
- Thermal
Resistance : 0.27 ~ 0.20 °C/W
- Noise Level : 18.0 ~ 27.5 dB ± 10%
FAN Speed Controller (FAN MATE 2)
- Dimensions : 70 (L) x 26 (W) x 26 (H) mm
- Weight : 20g
- Output Voltage : 5V ~ 11V ± 2%
- Allowable Power : 6W or lower
- Connector : 3-Pin
LO DO VIA X SOLI 35€ COMPRESA SPEDIZIONE...IN GIRO SI TROVA INTORNO AI 50€!!!
ACCETTO SOLO PAGAMENTO ANTICIPATO POSTEPAY!!!
CODA DI 24 ORE!!!
