Oltre che bella speriam ke balla
Processor
● AMD Athlon™64 Single Processor support
Chipset
● nVIDIA nForce3 150
- AMD Athlon™64 Single Processor support
- HyperTransport link to the AMD K8 CPU
- AGP3.0 8X interface at 533MT/s
- PCI 2.3 interface supporting up to 5 PCI slots
- 1 SATA interface
- AMD K8 CPU power sequencing protection logic
- LPC Bus 1.0 compatible interface
- 6 USB2.0/1.1 Ports
- 6-channel AC'97 Audio
Memory
● 2 DDR DIMM 184-pin slots on board
● Supporting Single-channel DDR400/333 SDRAM up to 2GBs
On-Board EIDE
● 2 x UATA 133/100/66 IDE ports (up to 4 ATAPI Devices)
● 1 x additional ATA-133/100/66 connector by Promise PDC20378 (SL-K8AN-RL only)
Serial ATA Interface
● 1 x SATA Port supported by nVIDIA nForce 150 (with Marvell 8818030 bridge)
● 2 x SATA Ports supported by Promise PDC20378 RAID Controller (SL-K8AN-RL only)
Integrated Super I/O
● 1 x Floppy Port
● 2 x Serial Ports
● 1 x Parallel Port
● 1 x PS/2 Mouse connector
● 1 x PS/2 Keyboard connector
● 6 x USB Ports (4 integrated, 1 optional cable to provide 2 more USB ports)
● 1 x Audio Port
● 1 x RJ45 LAN Port (SL-K8AN-RL only)
Expansion Slots
● 1 x AGP 8X/4X Slot
● 5 x PCI Bus Master Slots (32-bit)
Form Factor
● ATX Form Factor (220mm x 305mm)
BIOS
● AMI BIOS
● Flash Memory for easy upgrade
Other Features
● BIOS FSB, Vcore Setting ● H/W Monitor
● BIOS AGP, DIMM Voltage Setting ● SATA RAID 1, or RAID 0 (SL-K8AN-RL only)
● BIOS Writing Protection ● STR Function (Optional)
● LAN function (SL-K8AN-RL only) ● SmartDoc. Anti-burning Shield (Optional)
● 6-channel AC'97 Audio function ● RedStorm Overclocking (Optional)
notate le feature del bios :roll: :roll: :roll: :roll:
QUI
