nella schermata del BIOS non mi lascia cambiare i parametri della cpu
e ho dei problemi sul suriscaldamento della scheda video RADEON X300/X550 Series (0x5B60) 256MB
ho un Intel(R) Pentium(R) 4 CPU 2.93G 515 (estimated)
Technology : 0.09µ
Features :
VME - Virtual Mode Ext. : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
APIC - Local APIC Built-in : Yes
SEP - Fast System Call : Yes
MTRR - Memory Type Range Reg. : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
DS - Debug Trace & EMON Store : Yes
ACPI - Software Clock Control : Yes
SS - Self Snoop : Yes
TM - Thermal Monitor : Yes
HTT - Hyper-Threading : Yes
SBF - Signal Break on FERR : Yes
MON - Monitor/Mwait : Yes
DSCPL - CPL qualified Debug Store : Yes
TM2 - Thermal Monitor 2 : No
CID - Context ID : Yes
EST - Enhanced SpeedStep Tec... No
XD Bit - No-execute Page Protec... No
VT - Vanderpool Technology : No
Miscellaneous :
FPU - Co-processor Built-in : Yes
CX8 - CMPXCHG8B : Yes
CX16 - CMPXCHG16B : No
CMOV - Conditionnal Move Inst. : Yes
CLF - Cache Line Flush : Yes
FXSR - Fast Float Save & Restore : Yes
DAZ - Denormals Are Zero : Yes
MMX Technology : Yes
SSE Technology : Yes
SSE2 Technology : Yes
SSE3 Technology : Yes
EM64T Technology : No
IA-64 Technology : No
PBE - Pend. Brk. EN. : Yes
LAHF - LAHF/SAHF Inst. : No
Features Hyper-Threading :
Technology Enabled : No
Addressing Information :
Physical Addressing max. : 36-bit
Linear Addressing max. : 32-bit
Advanced Settings :
In Order Queue Depth : 12
Fast-Strings : Yes
x87 FPU Opcode : No
Split-Lock : Yes
Performance Monitoring : Yes
Prefetch Queue : Yes
Branch Trace Storage : Yes
C1E - Enhanced Halt State : No
Temperature Control : 67 °C
PRB - Performance Requirement Bit : No
Mainboard Upgradebility :
Socket/Slot : Socket 775
Upgrade interface : Socket 478
Supported Speed : 4000 MHz (or more)
Supported Voltage : 1.4V
come devo fare ??????? :mad:
