Potete scaricarli QUI
Windows XP Driver Versions 25 mb de robba
Audio driver 3.66 (WHQL)
Audio utilities 3.66
Ethernet driver 3.63 (WHQL)
GART driver 3.34 (WHQL)
Memory controller driver 3.38 (WHQL)
SMBus driver 3.38 (WHQL)
IDE In-the-box driver 3.58 (WHQL)
IDE 2.0 NVIDIA driver 3.66 (WHQL)
Display driver 52.16 (WHQL)
Installer 3.77
WHQL certified kit for nForce, nForce2, and nForce3
First release of NVIDIA IDE driver for Windows XP and Windows 2000
General compatibility fixes
Audio Improvements:
Realtek ALC655 codec support added
Fix for BSOD on loading DLS files
Reduced susceptibility to audio glitches under heavy system load; additional fixes for 6 channel GetPosition glitches
ASIO support for recording at sample rates other than 48kHz; lower and more predictable latency
Fixes for NOLF. The 3D minimum and maximum distance and the roll off factor were not being taken into account for air absorption. Also modified reverb gain so that the max distance was taken into account
Fix for EAX reverbs; initialized EAX reverbs to off when querying for the EAX listener interface; updated EAX property handlers to ignore invalid parameters instead of range limiting -- this matches Creative EAX behavior
NUOVA RELEASE DRIVER NVIDIA 3.13
- wasky
- Supporter
Ultima modifica di wasky il 04 nov 2003 03:32, modificato 1 volta in totale.
My Gallery on Deviant ART
