Unico NUOVO HDD MP3 / MP4 / foto media Player. Il tuo lettore portatile di MPEG4 / Divx Player; Il tuo lettore portatile di LIBRERIE MULTIMEDIALI , si connette alla TV o al videoproiettore o ad altri dispositivi Audio/Video o a
NUOVO!!! Supporta il formato NTFS e audio DIGITALE cx 5.1
Lo puoi usare per salvare i tuoi film DIVX direttamente sull' hardisk e vederli direttamente sulla TV senza dover masterizarli. Lo puoi usare anche come un hardisk USB e salvare qualsiasi file trasportandoli su un altro computer o salvare i tuoi DIVX favoriti, le tue canzoni MP3 e goderteli in TV.
● Power: DC 5V
● Power Consumption: 800mA
● Video Signal system: AUTO/ NTSC/ PAL
● Playable programs:
MPEG4(DIVX XVID AVI), DVD, SVCD, VCD, JPEG, MP3, CD-DA
● Video Output: 1Vp-p +/- 0.1 (75Ω)
● Audio Output: 2.0 Vrms +/- 0.3V
● Features of the audio signal output:
Frequency response: 20Hz-22kHz
S/N: more than 90dB (1kHz 0dB)
Audio distortion: lower than the test level
Crosstalk: more than 80dB (1kHz 0dB)
● gross weight(packed): 900g
● HDD: need assemble in addition
● Remote control system: infrared impulse, DC 3V, button battery
PREZZO 50e
Scheda madre Fic AM37 socket A - Formato: MICRO ATX 19x24cm
Supporta socket 462 Athlon Xp, Duron, 200266Mhz Fsb, DDR PC2100, AGP 4X, LAN AUDIO VIDEO INTEGRATI Costruisciti il tuo CAR PC o mini PC con questa splendida scheda ALL-IN-ONE
Processor
Athlon XP model 8 1700+ and up. Athlon
XP model 6 1500+ to 2100+. Duron
model 7 1G and up. Duron Model 3 950Mhz. Maxiumu Icc core supported:
Up to 46A
Chipset
VIA KM266
VIA VT8235
BIOS: EEPROM 2 Mbit
Memory
2 Dimm sockets
PC1600/2100 DDR SDRAM support.
SPD support
Liinear Power Supply: Richtek RT9173A.
Audio
AC97 revision 2.1 codec only.
ALC202A/ ALC650 Codec support.
Onboard I/O Connectors
1 PS2 Mouse. With optional 5V Stand by power.
1 PS2 Keyboard connector.
Keyboard Mouse Wake-Up from both S1/S3/S5
Audio connectors on rear side: Microphone-In, Line-In, Line-Out
1 VGA connector
1Parallel port
4 USB 2.0 ports
1 Serial Ports with support for wake on ring
1 LAN connector, including a LAN link beat LED. Dual COlor Mode support.
External I0 ports follow FIC back I0 panel standard.
Onboard IDE
2 dual-channled enchanced PCI bus master IDE conectors, ATA 66/100/133
Expansion Slots
3 PCI Comply with PCI 2.2 33 Mhz/1 CNR support AC97/MC97
Front Side Bus
100/133 MHz.
Graphical Interface
North Bridge (integrated graphics)
LAN
Controller: Realtek 8100BL
Wake On LAN
Boot On LAN
Form Factor
microATX
9.6' x 9.6'
Power Management
ACPI 1.0 rev. 1.0 compliant
PnP 1.0a
SMBIOS 2.3, WFM 2.0
USB 2.0
Suspend to RAM (S3) supported.
Suspend to Disk (S4) supported.
Wake-up from USB in S4 mode
NOVUS Features
BIOS Guardian
HotKey - Overclock Partner
PREZZO 35e
RAM pc133 2 x 256mb ECC 133mhz per server totale 512mb.
PREZZO 35e
IMON LT 2.4 g Vendo splendido usato una volta, senza un graffio, con i programmi necessari per trasformare il tuo pc in un media center htpc
PREZZO 70e
RECENSIONE
