ABIT AN7 vs DFI Infinity, clock per clock benchmark result
asphalt
Messaggio da asphalt »
qui:
http://www.overclockerindo.com/modules. ... 16889da434
naturalmente con bios moddati..che trovate quì:
http://s6.invisionfree.com/underclock/i ... wtopic=184
1. Changed the Optimal and Aggressive CPU Interface Table above 200 MHz FSB:
- DISABLE CPU Interface has been modified to be more user-friendly
for high FSB overclocking
- ENABLE CPU Interface now recalls the lost bandwidth when FSB
is above 200 MHz and at a multiplier that is under 10
2. No L12 Mod needed for 133MHz & 166MHz. All CPU will be running on 200MHz CPU Profile
3. Command Per Clock: disable
4. increase memory bandwith efficiency (NF7 bios by Mr Trats)
5. esiste anche per NF7S rev2
