CIAO A TUTTI IO HO UN PROBLEMA CON I GIOCHI.DA UNA SETTIMANA CHE HO IL PC NUOVO ASSEMBLATO E DA SUBITO HO AVUTO PROBLEMI CON I GIOCHI,IL PROBLEMA è CHE IL GIOCA PARTE MA HO TEMPO MASSIMO 3-4 MINUTI E POI O SI BLOCCA O SI RIAVVIA.
HO PROVATO A SCAMBIARE LA RAM IN UN ALTRO SLOT MA DA LA STESSA IDENTICA COSA IO HO UNA SCHEDA MADRE ECS KT600 AMD DURON 1,2GHZ UN BANCO DI RAM DA 256 SCHEDA VIDEO ASUS 9570TD 5700FX NVIDIA COSA POTREI FARE?
i giochi nn vanno
