Base-stealing in MLB The Show 25 is more than just holding L1 and praying your runner makes it. If you want to turn close games into wins, mastering advanced base-stealing tactics is a must—especially in ranked or Diamond Dynasty games where one extra run can make the difference. In this guide, we’ll break down 11 smart techniques to help you swipe bags with confidence and improve your scoring game.
Whether you’re saving up or planning to buy MLB The Show 25 Stubs to build a faster lineup, these tips will help you get the most out of your baserunners. Let’s dig in.
1. Study the Pitcher’s Rhythm
Before attempting a steal, observe the pitcher’s timing. Count how long they take to deliver the ball from the stretch and identify if there’s a pattern. Many online pitchers fall into habits you can exploit.
2. Use the Leadoff Wisely
A good lead is crucial. Tap L1 once to take a standard lead and twice for a more aggressive one. Don’t take the max lead unless you're confident the pitcher won’t quick pitch or pick off.
3. Control Your Jumps with Precision
Timing your jump is more important than raw speed. Hold L2 (or your platform’s steal button) and release right as the pitcher begins their delivery—not before. Hesitate even slightly, and you’ll be gunned down.
4. Steal with High-Speed, High-Steal Players
Speed alone isn’t enough. Prioritize players with high Steal and Speed ratings. Many players buy MLB The Show 25 Stubs to grab elite cards like Rickey Henderson or Ronald Acuña Jr. on Xbox and other platforms for this exact reason.
5. Know When Not to Steal
Even with top-tier runners, don’t try to steal on 0-2 counts or when your hitter is red-hot. The risk-reward ratio isn’t worth it. Play smart and wait for favorable situations.
6. Use Hit-and-Run for Distraction
Mix in hit-and-run plays. A well-timed swing can distract the catcher or slow down their throw, giving your runner a better chance. Just make sure the pitch is hittable, or you might ruin the entire sequence.
7. Steal Against Catchers with Low Arm Accuracy
Some catchers look intimidating on paper but struggle to throw accurately. Check their Arm Strength and Arm Accuracy stats before making a move. These details are easy to scout if you're using U4N’s roster insights or in-game comparisons.
8. Pick Your Pitch Counts
2-1 or 3-1 counts are often overlooked steal opportunities. Pitchers don’t want to risk a walk, so they’re more likely to throw a fastball down the middle. That’s your perfect chance to steal.
9. Utilize the Delay Steal in RTTS
In Road to the Show (RTTS), experiment with delay steals. After a pitch is delivered, pause briefly, then take off. It catches many CPUs (and sometimes players) completely off-guard.
10. Mix in Fake Steals to Bait Throws
Flicking the right stick to simulate a steal without actually going can trigger a rushed throw or distract your opponent. This works especially well online when players panic under pressure.
11. Practice in Custom Practice Mode
Repetition breeds perfection. Use Custom Practice to test various base-stealing situations. Simulate different pitcher styles, timing rhythms, and catchers. The more you see, the better you’ll react in live games.
Mastering these 11 advanced base-stealing techniques will give you a major edge in MLB The Show 25. Whether you're grinding events or investing your MLB The Show 25 Stubs Xbox to build a speed-focused team, smart base running adds real value. If you're trying to stay competitive in Diamond Dynasty without overspending, platforms like U4N offer insights and strategies to maximize your gains.
U4N - MLB The Show 25: 11 Advanced Base-Stealing Techniques for More Runs
